JD 455 buying advice please
   / JD 455 buying advice please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
I'm looking at buying a John Deere 455 with rear 3PL and PTO fitted.
Price is $NZ6500 (about $US4500).
You can see pictures online here : John Deere 455 | Trade Me
Intended use is :
Replace my Kubota F1900 4WD 60" mower
Replace Kubota B2150 tractor used with tow hitch for moving trailers
Replace Iseki SG15 mower (which doesn't get used)
Provide hydraulic flow to a McHale 995LM bale wrapper
I've checked the hydraulic flow requirements and it should run the wrapper ok (needs 6L/min @ 60 Bar)
Questions :
Will I be disappointed with the mowing performance compared to my F1900 ?
Can it lift 300kg (600 lb) on the rear 3PL ?
Are there any weak parts in the 455 design that I should look at on this particular machine before buying ?
Thank you
   / JD 455 buying advice please #2
Rock solid tractor.. and mowing is what I find it does best, and not less than other chores.
IMO, the 455 is better than any other model (edit: of lawn/garden ) Deere has produced since.
(..and agree with CADplans, and might be best to add a PTO hyd. pump, as the PTO will run on continuous basis)
   / JD 455 buying advice please #3
The 455 is still a GT,, with hydraulic flow being supplied by a hydrostatic transmission charge pump,,,
rather than an actual gear pump.
The flow is intended for occasional use, like steering, and mower lift,, not continuous use.
It is a great garden tractor,, maybe not the replacement for the multitude of machines you list,,,:confused2:
So it's not going to run my wrapper for 6 hours continuously.
Is the PTO rated for high duty cycle or is it also expected to be occasional use only ?
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
