JD 455 With JD40 FEL?
   / JD 455 With JD40 FEL? #11
Rlbol said:
1*Any one have a JD455 with either a JD 40 FEL or a different FEL? I am curious how it functions? Good or Bad? how much weight can it move?
2*I am looking at a 455 with the FEL already.
3*I have not purchased anything yet. I looked at the Bx's and they are nice
4* but I just don't think i will ever use them. I also looked at the 2305 but I just don't think i will use them that much.
1*Not as good as a Sub=compact.
2*What kind of a price is on the JD455?
3*I thought in this post
http://www.tractorbynet.com/forums/1230750-post23.html
that you had about made your decision on what to purchase.
4*What has swayed you back over towards the JD455????
   / JD 455 With JD40 FEL? #13
Shaman said:
You buy those BX yet?
Talked to the dealer on the phone yesterday evening.
He is supposed to call me back with a price on the following Package.
1 New BX1500
1 Used BX1500 with only 350 hours on it.
He sys it's really nice and parked beside the new one it's hard to tell them apart.
I MMM
1 used Front Blade
1 used rear tiller.
IF the price is right and everything else clicks I will take both tractors and the 3 attachments.
   / JD 455 With JD40 FEL? #14
TimS said:
1* As far as I can see, the rear PTO is only really useful if you want to use a mechanical tiller -
2*they make a hydraulic tiller that runs off the mid-PTO too.
3*The PTOs come up fairly often on eBay, but they're not cheap - usually go for about $500.
1*Or a rear finish mower or a brush hog.
2*At anywhere from 2000 to 3500 bucks.
3*Plus 2 or 3 hundred dollars to install it.
plus you also have to spend another $500 to 800 for a 3 point hitch so you can attach the Tiller finish mower brush hog or any other rear mount implement to the tractor.
The prices I have gotten on the BX2350 with 60"mmm and FEW is 11.5k I then found a 455 with FEL and 54"mower for 3600 so that is a big difference. But I am just get the 2350 and be done with it because I am thinking about running a bush hog as well and I dont think the 455 will handle that to well. decisions decisions
   / JD 455 With JD40 FEL? #16
I guess there should be a big difference in price between a 10 year old used garden tractor and a new S=Compact but there is also a huge difference in what you get for your money too.
Does the JD455 have a rear pto and a 3 point hitch if not you will have to add them both at a cost of around $1200 to $1600 before you can use a Brush hog ,rear mower or Tiller on it.
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
