JD 4600 temperature goes in the red within a minute or so running from cold.
   / JD 4600 temperature goes in the red within a minute or so running from cold. #32
I have a JD 4600 with same temp gauge problem. My fuel gauge went wacko years ago. Also had problem with thermistor. JD electronics suck Did you ever find a quick easy and cheap fix? I'm leaning toward an aftermarket gauge
The only thing you can do is to bolt on a cheap automotive temp gauge somewhere out of the way but still in view.
And just pull the wire from behind the dash and use that to wire up the new temp gauge.
Cheers,
Frits.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Rhino DB150 (A57148)
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
