JD 4610 honking/squeaking noise at startup
   / JD 4610 honking/squeaking noise at startup #1
rkncirclec
WA
JohnDeere 4610
When I start my JD 4610, I have a honking noise coming from the left side of the tractor next to the hydraulic filter.
Operationally, everything seems fine. No leaks. I did not run over a chicken or duck. But it feels like a pump is going.
Any help appreciated. I'd rather fix it myself than pay the man.
Thanks
B
   / JD 4610 honking/squeaking noise at startup #2
Maybe change the hydraulic filter.
I replace the hydraulic filter, cleaned out the suction filter, replace the tranny filter, all new hyro fluid.
   / JD 4610 honking/squeaking noise at startup #4
Can you make a video?
   / JD 4610 honking/squeaking noise at startup #6
My 4310 does the same sound. It is in the hydraulics. I believe the sound is the pressure building against the valves as it pressurized.
Any adverse effects so far?
thanks
   / JD 4610 honking/squeaking noise at startup #8
Mine has been like that for at least 500 hrs. Everything works fine.
Volvo L306 (A57148)
Volvo L306 (A57148)
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
John Deere 6125R (A60462)
John Deere 6125R...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
