JD 5083e -opinions?
   / JD 5083e -opinions? #31
HP is directly proportional to Torque X RPM's. Higher RPM's is helping the smaller Kubota engine HP. So, what is the real hp of the smaller engine at the lower rated PTO speed? A fair amount lower. I think it is a marketing ploy.
Your suggesting they took the measurement for PTO HP at somthing other than 540 RPM? Thats a big accusation from a company who took years to use anything but bucket center loader measurements! Why is this even a talking point? I could not tell you the last tractor I was on that had its PTO speed at max rpm.
on the weights. Kubota's book weights are always shipping weights, they are not configured ballasted weights. Most of those tractors go out with cast iron rims, loaders, etc that normally put them up in the 8000-9000lb range.
   / JD 5083e -opinions? #32
Here are some facts which come straight out of the Operators Manual for my recently purchased 2011 Kubota M110X tractor.
Net PTO hp is 95 at engine speed of 2600 rpms (ref Specifications Table, page 3)
PTO rpms is 540 at engine speed of 2205 rpms (ref Specifications Table, page 4)
Net Engine HP is 107.5 at 2600 rated engine rpms (ref Specifications Table, page 3)
   / JD 5083e -opinions? #33
Look at this link:
http://tractortestlab.unl.edu/Misc-tests/Kubota_M100X.pdf
you will see a Nebraska Tractor Test report for the kubota M100X tractor, which is similar to your tractor.
In the report you will see that this tractor made 85.15 PTO HP @ 2600 engine rpm, it made 87.2 PTO HP @ 2401 engine rpm, and it made 85.61 PTO HP @ 2205 engine rpm. So, this tractor makes slightly more PTO HP at 2205 engine rpm (this corresponds to 540 PTO rpm) than it does at the 2600 engine rpm speed. I'm pretty sure that your tractor will make 95 PTO HP at a PTO speed of 540 rpm. Does this help to answer your question?
I would also like for Kubota to make this more clear, I don't think I've ever run my M8540 close to 2600 rpm. I've seen in the engine section of a Kubota brochure a graphic for the M9540 with engine HP vs. rpm, engine torque vs. rpm, and fuel usage vs. rpm but the picture is small (also does not show PTO HP vs. rpm).
   / JD 5083e -opinions? #34
Look at this link:
My previous comments on the topic of engine and PTO horsepower are all in reference to BLEED GREEN's entry #27 above in this thread for the Kubota M8540. The question of "what is the hp of the smaller engine at the lower rated PTO speed " is still not answered anywhere, not for the M8540, M100X or M110X. The Kubota 3.7 L diesel engine is used in several different tractor models with varying PTO and engine horsepower and I don't think one can extrapolate engine and PTO HP data or tendencies between the models. The main reason I showed the M110X data was to illustrate the same point of "what is the engine hp at the lower rated 540 PTO speed" which I feel is the standard and close to where equipment is to be operated, not 2600 rpm (maybe I should have reiterated that above).
BTW, I never run my M110X over 2200 engine rpms where the PTO speed is 540 rpms. Haven't figured out why Kubota specifies rated engine speed of 2600 rpms (maybe to achieve higher travel speed on the road?). Thanks for pointing out the Nebraska test data is available for the Kubota M100X tractor.
   / JD 5083e -opinions? #36
The OP has taken delivery of a Kubota M8540 HDC.
Sorry - I should have posted that I went with the Kubota but I think the discussion about HP is a valid one. Please continue.
   / JD 5083e -opinions? #38
Congrats!! I had an M8200 cab tractor (predececessor to M8540) which served me well for 8 years before trading on the new M110X model a few months ago. I'm confident your new Kubota will serve you well. Good Luck.
   / JD 5083e -opinions? #39
The e's will now have electrohydraulic pto engagement, so no more dry pto clutch (room for a buddy seat now), and an air seat option.
I was pretty much set on a MY2012 5085M, but after taking a closer look at the MY2012 5083e, I'm wavering towards that instead, especially now that you can get the same hydraulics and the control layout on the right of the operator seat is identical. Sure, implement gpm is 15.9 as opposed to 18.4, but I doubt that will be noticeable under most conditions.
Here's the 5085M right hand controls:
And the MY2012 5083e:
So I would loose the throttle control on the fender and instead of being able to select 540 vs 540E via this lever next to the PTO knob:
I would select it via this handle (where is this btw?):
I'd give up the EH Hitch controls: (and the ability to adjust from the rear fender mounted switch)
And instead use these mechanical controls: (They do look a lot nicer and easier to get to than on older E Limited tractors)
And instead of selecting MFWD via this EH toggle switch (which also features auto MFWD engagement):
I'm stuck using this "old fashion" lever to the left of the operator seat: (and I think this is the only item that could possibly interfere with being able to install a buddy seat)
But I do get this indicator now:
Instead of this EH diff lock:
I get an "old fashioned" mechanical foot pedal:
Which, if anything like the one on my 4700, sometimes mean you really have to step on it to get it engaged, and then more or less stand on it to keep the diff locked.
A big plus is that I'm now able to get the M deluxe air seat as a standard $675 option:
My out the door price for a decked out 5083e w/ H260 loader would be around $15,500 less than a decked out 5085M w/ loader. This, combined with the fact that my dealer has a virtually brand new 49 backhoe with a frame that fits the e-series for $4,900, makes the 5083e vs. the 5085M with a 595 backhoe even more attractive, around $22,000 more attractive in fact.
In addition to the differences outlined above, I would loose the radial tires, corner post exhaust, 16/16 transmission and the single point hydraulic disconnect for the H260 loader, but for $22k in savings, I'm thinking that I might just be able to live with that, although I'm going to talk to my dealer about the possibility of getting the radial tires.
I do need to make the buddy seat work (wife is dictating). The only control on the left of the operator seat now is the MFWD lever as shown in the pic above. I suspect I'll still be able to get to it, at least when nobody is in the buddy seat. According to the dealer, the buddy seat bolts directly to the inner fender by drilling 3 holes in it.
Anyone here with a 2012 5083e yet that would be able to comment on what's on the left inner fender that would prevent bolting in a buddy seat?
Here's the comparison between the two configs that I'm looking at:
With the savings of going with a 5083e w/ 49 backhoe, vs. 5085M w/ 595 backhoe, I could get some really nice additional implements!
I really like the Ms, but since I'm only a weekend farmer, it is really hard to justify. I'll be putting in an order with the dealer next week for either the 5085M or the 5083e.
   / JD 5083e -opinions? #40
Looking at the location of the 4x4 lever and considering the layout of my 5075M - I don't think you'll have a problem installing a buddy seat at all.
I've got a buddy seat and the location of the shift lever is right where I store a roll of paper towels and whisk broom. :laughing:
So, if the lever doesn't stick up too high - it shouldn't hit the side/rear of the buddy seat at all.
One observation regarding "apples vs apples" - you've got the price of the M loaded up with about $3,600 in optional tires that you don't have on the 5083e. And another $1,300 with the corner post exhaust and buddy seat that's not included with the 5083e. So, there's $5K of "saving's" that's not really savings...
Just sayin'...
The e is a great deal - no gettin' around it!
One added consideration that I've seen discussed here on TBN - the differences between the engines on the e and the M. IIRC - there was a distinction regarding the turbo's and the injector pump and injector system.
Check the Nebraska tests... I think the M has better fuel economy than the e, as well.
AKfish
2023 Caliber Trailers GH840MST 40ft 6 Ton T/A Gooseneck Flatbed Equipment Trailer (A56858)
2023 Caliber...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58216)
HYDRAULIC AUGER...
WOODS 1033674 SUBFRAME KIT (A58376)
WOODS 1033674...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
