I have not. I don稚 have any breakaway hoses to use to test.Have you tried sticking in a hose into your SCV and filling a clean pail?
What would that tell me? Testing for oil through put?
Sounds like to me your main relief valve is stuck open. If you have a loader and it works then the 3pt safety valve could be stuck open. One other thing is the O rings where the 3pt mounts to the rockshaft housings.
Does your tractor have knob to control the drop of the lift? If so see if it is screwed tight.
You stated your tractor has control valve for FEL but no FEL & no breakaway couplers. Is that correct?
there are different variations of the system depending on whether you have draft control or not.
you can look up diagrams here for the system:
John Deere Parts Catalog
No loader. I have the joystick and four hoses coming off the rear hydros that are mounted and have 4 break aways mounted beneath the joystick. I was making reference to the fact that I don’t have any way to plug anything into the mounted break aways for testing.
