Buying Advice JD 5105M vs. JD 6330
   / JD 5105M vs. JD 6330 #31
Also, I would pass on the SL. I have a 542 SL on my 5525 and well - I don't like it. Run the loader a little while - you will do your own SL without a problem.
The load dampener is handy for hauling hay bales across bumpy pastures. Loader Accumulator I believe is the official name.
D.
It does have an accumulator. John Deere calls it LSS. Loader Suspension System. It's on my WISH list for the 6415
   / JD 5105M vs. JD 6330 #33
I love the LSS on my 5085M with the on/off switch in the cab.
I had a 6405 loaner for a while when I was waiting on my M. It was a brute of a machine for sure. A lot more than I need. I was able to move a lot of dirt with it in short order though! :)
   / JD 5105M vs. JD 6330 #34
Well I now see it is an old post. I have a 5105M and neighbor has a 6420, which is same family as 6330. Which did you pick?
5105M and 6330 has same basic engine block, different turbo set up. 5105M a smaller frame and has geared transmission. Advantages of 6330 added weight, and the power quad fully syn transmission. 6330 is quiter and a little more sure footed. For field work I would go with 6330. For alot of field work really need a 7 seriers at least. 6 cyn has more tourque on up hills and heavy hay.
The OP hasn't been on her since last Dec. so I doubt you'll get an answer unless he gets email notifications on this thread but I'm sure others can answer your questions.
   / JD 5105M vs. JD 6330 #35
Mine has a valve on the back. No fancy switch for my rig.
D.
2004 Ford F250 (A50515)
2004 Ford F250...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
2012 Killbros 110 Grain Cart (A50514)
2012 Killbros 110...
Tires 25x10-12 (A50322)
Tires 25x10-12...
Ford 1320 Tractor (A50514)
Ford 1320 Tractor...
