JD 5425 dry clutch needs adjusting
   / JD 5425 dry clutch needs adjusting
Turns out the carrier bearing was bad and the guide for the bearing was worn. The guide for the throw out bearing was worn. And the clutch cable had been stretched and was replaced. The cable may have been the incorrect one from day one.
R
   / JD 5425 dry clutch needs adjusting #12
I had similar problems with the PTO slipping on a 5105 I had. Was able to adjust it the same way and it solved the problem. It showed up when running a rotary cutter. It would get in tall grass and quit cutting. The motor never bogged.
Lot (3) Rolls of Barbed Wire (A50515)
Lot (3) Rolls of...
UNUSED MOWERKING SSECAG-Y AUGER BITS (A51244)
UNUSED MOWERKING...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
(10) 7 x 9 Treated Posts (A50515)
(10) 7 x 9 Treated...
