jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
There is a drain and a screen at the bottom of the transmission that was removed to try and access the tube. We will remove them again today along with an access panel where the fill tube is on the top end of the trans. The only problem is that there is huge filter with big 1" lines that have to be removed in order to access the panel. I'll keep you guys posted.
How big is the opening you put the tube into? Can't you use a fiber optic scope to look around inside the transmission from the dipstick port or refill port? I suspect the size and type of tube inserted is largely responsible for the hose sticking. It probably got itself wedged between two surfaces and just got tighter as it was pulled. If you could get a wire hook down inside to grab the end of the hose, you might be able to get it out. Having a scope to guide you would be an absolute necessity, but I'd spend a lot of money on high-tech gadgets before doing disassembly. I see your challenge as two-fold: finding the hose and getting it out. Both things will test your patience for sure.
