JD 955 with weak 3 point lift
   / JD 955 with weak 3 point lift #1
kevinfrog
Previously: Yanmar YM 2000 Currently: JD 955
I bought a JD 955 last week that seemed fine until I got home and put something on the rear lift. It's weak. Everything else works great. Excellent wheel power and front loader power. The rear lift will not lift empty arms at idle. At full RPM it will lift about 200lbs on the arms (me standing on the arms). I put my old 5ft rear mower on it, and it barely gets the front wheels off the ground. The tractor came with a 5 ft belly mower and it lifts very very slowly at full RPMs. It won't lift at all at 50% throttle. I've been googling around and I've checked the hydro fluid level and I've drained it and cleaned the filter screen (barely anything there before cleaning it). The flow control knob under the left side of the seat is open. I've tested it at various points in the knob travel. It will slow the movement rate as expected. It just feels like there is a partial flow blockage some where since it will kinda work at increased power settings. I've also removed the FEL and there was no change after that. Any thoughts? I am also going to have a Tech manual by tomorrow.
   / JD 955 with weak 3 point lift #2
Welcome to TBN
If your tractor has option of scv be sure control lever is in neutral. It's possible the rockshaft piston seal has failed or the flow divider valve is blocking flow to 3 pt hitch.
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2010 CATERPILLAR 303.5C CR EXCAVATOR (A60429)
2010 CATERPILLAR...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
