Hi all!
I just wanted to get your opinion on a new purchase I made. I just bit on a JD955 with 72" belly mower.
It's a 1998 with 540 hours on it. I'll post some pictures up of it next week when I pick it up, but it is very clean and everything works on it. It was very well taken care of. I only see a tiny bit of rust on the front cover at the bottom (likely a bit of corrosion from the battery located behind?). Other than that it's just about perfect.
Got it for $7500 cash. How did I do? I got it to perform duty on my current 4 ( possibly to be expanded to 7/8) acres.
So what is the general perception of this particular machine? Most info I found on them (couldn't find a whole lot) seems to point to a good piece.
Any advice/ gotchas I should look out for on this model? I understand it's 12 years old, but it appears to have barely been used, and has the power in a compact size I was looking for.
This is my first tractor. I have a lot to learn. I plan to spend time on this forum doing just that.
Regards,
Jx
Regards,
Jx
