JD Ballast Box- Reinforcement
/ JD Ballast Box- Reinforcement #1
Trails2004
Outside
2009 JD 3520
I have searched and could not find any information- If this is a duplicate thread my apologies>
Has anyone been concerned with filling their BB with cement - without reinforcing the 3 point pins in the box?? A coworker mentioned I should not use cement for fear of damaging the 3 point lower pins..
The pins are welded to a piece of strap on the outside of the box- He beleives the pins should be connected to each other- with a bar or similar on the inside of the box.
I have a JD 790 if that helps you with your comments//
Many Thanks!!
/ JD Ballast Box- Reinforcement #2
I just happen to have both of those, a JD 790 and a concrete filled JD weight box. :thumbsup:
I also was a little concerned about the pins myself but did nothing about them.
Going on 3 years so far, maybe I was just overly concerned. ;)
/ JD Ballast Box- Reinforcement #3
JD has been making these box's for a long time, and they also recommend filling them with Portland Cement to the brim-even adding the extension to them for the bigger tractors so you can get more cement in them...
I am sure if there was a problem it would have shown up by now! I believe the JD engineer's have done their homework on this:thumbsup: And I am sure your coworker has good intentions but there is no reason to fear filling the box with cement or anything else.
Mine is 6 years old and filled with cement;)
/ JD Ballast Box- Reinforcement #4
My JD box has over 1,000Lbs of LEAD in it!!!!:thumbsup: Its yet to bend, and has been put thru ****. Its rock solid, don't worrk about it! There is a reinforcing strip welded to the box where the pins go thru If my memory serves me right.
2008 Volkswagen EOS (A61574)
2008 Volkswagen...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
Case SV280B (A62177)
