JD/Kubota/Kioti
   / JD/Kubota/Kioti #21
The DK4510 and larger is not available with a hydrostatic transmission, but is available with a standard synchro tranny which will require clutching or a hydraulic shuttle which does not require clutching. The DK4510 is missing a few things. most notably telescoping lower links and telescoping stabilizers.. However that can be fixed with the addition of a good quick hitch and hydraulic top and tilt. The 4wd is actuated by mechanical lever instead of electric/hydraulic switch, but that may be good or bad depending on your opinion.
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2016 Freightliner Derrick Digger Truck (A55973)
2016 Freightliner...
