jd5020 series
   / jd5020 series #11
Your Jd has a loose governor spring. You can tension the spring so that the rpm regime is tighter. If you over tighten it, it will be impossible to keep constant revs because it will add and decrease the amount of fuel injected 2 times a second. turn it too loose and you wont be able to rev at all /forums/images/graemlins/grin.gif
   / jd5020 series #12
   / jd5020 series #13
thanks for your answer, i'll investigate that screw, and then rotate it softly.
by the way, i remind myself that variation on engine revolutions, happens veru quicly, for example with a trailer, when i acelerate.
   / jd5020 series #14
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
