JD5425 no electric power
   / JD5425 no electric power
I have been looking for a place on line where I can download the schematics for JD5425 so we can trace the electrical short easier. Any suggestions? May have to purchase a deck manual. Craig
   / JD5425 no electric power #12
   / JD5425 no electric power #13
That grinding noise is your starter, no matter what your testing told you. It will eventually go bad as all of the ones on this series tractor do. It's a known failure item. Do yourself a favor and lift the leads from the terminal on the injector pump fuel shutoff valve and see if it will start. At least eliminate that.
Thanks guys. We are up and running again. Turned out to be the cold temp sensor on the side of the block.
Craig
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
2001 Genie S-60 Manlift (A57453)
2001 Genie S-60...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
PT 1000 Gallon Supply Tank (A57148)
PT 1000 Gallon...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
3650 (A47477)
3650 (A47477)
