JD744 w/noisy Yanmar 24hp Diesel
   / JD744 w/noisy Yanmar 24hp Diesel #31
WHPJD said:
I have a JD 2720 which was upset on its side, no damage except that the engine cylinders must have filled with fuel because when it was uprighted, it wouldn't turn over. I left it for a day and then it started but ran awful, HUGE blue smoke, rough, noisy. I ran it a few times for an hour or so and it smoothed out a bit but still blur smoke big time when it started and seems to have a "rattle" (lifter?valve?) that it didnt have before . JD serviced it , advanced the timing of the fuel pump, they said. I wasn't satisfied, they did it again and pronounced the tractor to be "normal" for a 2720. I neglected to tell them about the upset incident ( no visible damage, didnt want to void wrrty).
In any case, it still smokes too much and for too long (in my opinion) when started cold, and it still has this rattle which was not present before. It's more noticeable to me at higher rpm than at idle. No smoke when it starts warm, just the rattle (which JD svc says is normal). However, I am certain it is a result of the upset, anybody got any ideas?
Welcome to TBN!
If you're saying you are certain it's a result of the upset, and it didn't do anything like this beforehand, I would tell the dealer what happened. As it is now, they are kind of on a fishing expedition.
   / JD744 w/noisy Yanmar 24hp Diesel #32
I have "upset" my tractor a few times .. the cylinders fill with engine oil, one time the engine kept on running on its own oil, even tho I turned off at the key. You should not try to start them after a roll as you might bend a rod, best to remove the injectors , manifolds and turn the motor over and let the oil spray out. Dunno if you have caused internal engine damage, but the smoke is probably oil in the muffler, mine smoked for a while till it cleared .. hope it turns out OK
You should post a new thread about this in the JD ownin/operating section
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
UNUSED RETRACTABLE AIR HOSE REEL (A54757)
UNUSED RETRACTABLE...
