daryelcorran
- Joined
- Aug 16, 2022
- Messages
- 20
- Tractor
- Kubota MU4501 2WD
Recently had the exact problem with my JD 950. Pulled fuel line to injection pump and filled a quart jar with fuel. Let it sit for a few minutes and it had about 1/8th inch of water on the bottom of the jar. Drained all fuel from tank,lines and pump. Added new fuel and filter and it was good to go- until the next time it happens, and it will.Which a bad VR can cause. If the vr is not cycling properly, the battery can indeed fail to charge. Headlights can also be dim and instrument panels can be wonky. The voltage regulator controls the flow of electricity to every working part, including the engine. Bad voltage regulators have been known to cause engine stalling, acceleration issues, irregular engine timing, and misfires.
At this point, i would take off injector fittings and see what I am getting as pump out volume.
Yes sir, a plastic tub will work great. I do use a plastic tarp to cover the hood and console and engine.A shed is ideal, but with seven tractors needing covered, the little JD 950 is low man on the pole, so he sits outside. I had never heard of a Mr. Funnel that 5030 suggested, and after research that seems like a perfect solution to fueling any vehicle. I am going to order one off Amazon and give it a shot I use 5 gallon plastic fuel containers to fuel all tractors and the funnel will work for all of them. I set the container on the hood and use a clean hose from container to tank and pressurize the container and fuel flows into the tank with no spills and mess. Just like pulling up to the pump, only a bit slower.Good suggestion 5030-thanks.Or depending on the cause, put a plastic tub or something over the fuel gauge in the fuel cap. Rainwater goes right through those gauges.
