MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,194
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
You want to set the traps on the main tunnels, not the feeding areas that look like messed up carpet grass.
Put your heel into what you believe are the main tunnels every 10' or so. If you see a branch tunnel, put your heal in about a foot from each junction. If your heel prints get pushed back up in a day or two, that's an active run. Set your trap in the same location as your popped-up heel print.
Don't bother trying to trap mounds. Mounds are where moles push up excessive dirt from their tunnels. When they push the dirt up, it will trigger the trap well before the mole gets there.
What I like about the out 0 sight traps is that it straddles the tunnel and traps from either direction.
When the moles drained our swimming pool, I'd had enough. That was in August, and I started trapping. I got 29 that year. For the next 4-5 years, I stopped counting at 50 each year. After that, they finally thinned out and I got about 10 each year for 4-5 more years, and now I get less than 6 per year.
At the peak, I'd get 2-3 per day some days. I'd get two from the same hole in a few hours. It was like some kind of horror movie.
