Jima Y385T powered Mazda Pickup
   / Jima Y385T powered Mazda Pickup
You'll probably have to cut a hole in the hood and let the engine stick out on that one!
(I'm sure many would question why not a used Mazda engine vs. a tractor engine...)
If any of you are like me, then you enjoy finding out how much you can get out of your equipment. When I am running production machining jobs I enjoy finding ways to make the CNC mills run at the absolute maximum possible potential. On a large CNC mill it does no harm to the machine to run them that hard. (My last big CNC mill had over 8000 hrs of spindle time on it with no breakdowns!)
So when I was going to build a truck I wanted a commercial / industrial engine that should hold up to the same amount of "fun". That's the reason I did not go with a 'car' diesel.
Only time will tell if my selection was right. But so far the "fun" factor has been off the charts. Every morning I am just as excited to drive the truck as the first day I drove it. By far it has been the funnest project I have ever done.
I just put several new photos of the engine compartment and how it looks after 10k miles on "My Gallery". A little dirty but most everything is complete. I will be hooking up the A/C when it gets warmer.
Thanks,
-Dan-
   / Jima Y385T powered Mazda Pickup #34
Dan, real nice pics. Beautiful machine work and install. My compliments to you.
What year GMC is that in your gallery?
Regards, Harry
PS are you going to tell us how you balanced the flywheel? /forums/images/graemlins/wink.gif
   / Jima Y385T powered Mazda Pickup #35
someplace I'm missing the photos of this gallery? wheres the link?
Mark M /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif
   / Jima Y385T powered Mazda Pickup #36
How much oil does it use in 3000 miles?
   / Jima Y385T powered Mazda Pickup #37
I understand that the AC can use 5-15hp. Will you use different size pulleys on the crankshaft and AC compressor? I changed my 06 Chevy from the OEM 8 inch crank pulley to a 5.75 aftermarket and picked up 2 MPG.
   / Jima Y385T powered Mazda Pickup #38
Dan,
When I was 21 I dropped out of the Uni-versity and bought 10 ac. I built a bansaw saw mill and cut the logs off the land for my timber fame house. Should have seen the reaction from fam & friends. I like projects like yours.
Remember, the Wright brothers took an engine and put it on a glider. Both existing parts
Patrick
   / Jima Y385T powered Mazda Pickup #39
Spiker,
I was confused too. I found the pics that Danthefamilyman spoke of. To tell the truth I never knew there was a photo gallery.
/forums/images/graemlins/confused.gif but I do now.
Go to TBN main(Home) page, click on photos on menu bar, Now you have to find out which category Dan put them, hint they are in "Property, Land & Lifestyle" photos. I did try a search many times for his name using the search option but to no avail. Maybe something I am doing wrong.
Anyhow, here is a direct link to save you time. Then click on next image to see next pic. Hope this helps.
Dans Pics on TBN
   / Jima Y385T powered Mazda Pickup #40
Dan
One thing that might be of interest to a lot of us here that run this engine in our tractors is what alternator are you using and what was involved in interfaceing it to the engine?
2' Auger Extension (A50774)
2' Auger Extension...
2016 MACK CXU613 DAY CAB (A52141)
2016 MACK CXU613...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
2008 Wilson Hopper Bottom Trailer (A50514)
2008 Wilson Hopper...
