jinma 354 wont start, dead....
   / jinma 354 wont start, dead....
That is another option. I am not really too worried about anyone stealing it...our attack rooster is on guard!
Might anyone have a simple wiring schematic I could follow to incorporate the relay or relays that have been alluded to in this thread to protect the glow plug and or starter circuit?
   / jinma 354 wont start, dead.... #12
I have a cut-out switch in the negative lead from the battery to the frame, both for security and to ensure against a transient short leaving me with a dead battery. With that and the aforementioned relays I've had no problems with the OEM switch - so far. I do have a Cole-Hersee marine key switch in the tool box for when the OEM switch does fail. I recommend that all switches and relays on a tractor be marine grade. Much more dependable and robust, designed for exposure to the elements.
   / jinma 354 wont start, dead.... #13
Yeah, marine grade is good if you the tractor is never shedded. Otherwise they're comparatively pricey.
I'm going to assume you'll use the common Ford-type relay. The GP relay is easy to describe, I mounted mine upside down on an existing hood release bracket bolt. Disconnect the OE (green) wire from the buss bar, and attach it to the small post on the relay (marked S). Cut a section of 10AWG primary wire and connect from one large post to the large post on the starter solenoid where the battery cable is connected. Cut another section of 10AWG primary wire and connect the second large relay post to the buss bar.
If you don't have any trouble with that, I'll then talk you thru a similar process for installing/connecting the starter relay.
//greg//
Now I have gone and done it...got the new switch and tried to wire it. I thought I had it all hooked up correctly, had power at the switch turned ignition on, guages and lights came on, went to glow and the voltage meter dropped as it did before went to start heard a click or two but starter did not engage. I thought I may have switched a wire I was pretty sure I had the power wire in the right spot and the wire to the glow plugs was right so I switched the other two. Mistake...turned the key heard a click then everything went dead. Now, no power at the switch at all. I dont seem to have any power past the solonoid on the starter.
Is there a fusable link on the starter? Maybe I cooked the solonoid? It might have been a problem after I cooked the switch?
further ideas?
thanks,
craig
   / jinma 354 wont start, dead.... #15
further ideas?
thanks,
craig
I think you may need to slow down a bit. You said there was 12 volts at the battery at one point, IIRC? This is NOT enough voltage to start your tractor. Try charging your battery up on a charger and then go back to how you first had the wiring, before you decided to switch it around. When you get it running you should have around 14.25-14.40 Volts across the battery, and when you turn on your high beams that voltage may drop slightly. Until you get it wired right and started turn off the lights for now. Get it started and then check voltage, then add loads like lights, then check voltage again. One step at a time, verify what is working, then keep moving to next step. :thumbsup:
I switched the wires back to the way they were. I am getting no current at the switch at all wheras I was before. I am not getting any voltage upstream from the solinoid at all. The fuses are ok so I am guessing the solonoid got shorted or damaged?
   / jinma 354 wont start, dead.... #17
Go back to the original wiring setup I described, replace the 30A system fuse, use the compression release and a known good battery of no less than 750CCA. Thoroughly clean all four battery connections (with particular attention to the tractor frame end of the ground cable), try again.
//greg//
   / jinma 354 wont start, dead.... #18
Yes, I'd say you blew the main 30 amp system fuse. You shouldn't be able to burn out the solenoid that way.
'Wiring is best checked with a multimeter, not by switching wires until you get smoke. You can get a perfectly serviceable multimeter from Harbor Freight for under ten bucks.
Ok, you guys are good...turns out I had a bad connection on the ground at the battery. So, now I have powerback, I am pretty sure I have all the wires connected to the switch correctly but it wont start from the key, I just get a click. I put my charger on the battery and amgetting 14 volts, with tge key in glow it drops to 12 volts. I was able to jump the solonoid and the starter spins and it starts and runs so do I conclude I have a bad solonoid? Can yiu get just a solonid for these or does one have to get a whole new starter? Only other thing I can think of is a break in the wire or perhaps corroded terminals on the solonoid or starter...
thanks for all the help, learn by doing, right.
craig
   / jinma 354 wont start, dead.... #20
Could be almost anything, but a bad solenoid is way down the list of probable causes. What I suggest you do is go get a 12 volt 30 amp relay such as is used on headlight circuits and wire that in between the key switch and the solenoid. Use 10 gauge wire from the battery positive to the relay and from the relay to the solenoid. Use the existing wimpy wire from the key switch to the relay's coil contact and to ground. This way your key switch is only handling about 1 amp and the relay is carrying the heavier load of the solenoid. I did this on my Jinma and have never had another problem starting it. The 30 amp relay should only cost ten bucks or so and couple bucks for the 10 gauge wire.
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
Pallet of Miscellaneous Heaters (A52384)
Pallet of...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
