Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
If you're dropping from 14V to 12 V your battery is suspect. It may be taking but not holding a charge under load- glow plugs are a significant enough load to take the battery down if it is weak. As has been said, get a KNOWN to be GOOD battery and then try it. Also doing the relay to reduce the amperage through the key switch is the way to go now and in future. Again, don't jump to what YOU think it is, (solenoid), you are just guessing and that seldom solves this type of situation. Process is: verify BATTERY. Verify grounds, cables to/from chassis/to battery, verify fuses, wiring, components, (key switch, solenoid, starter, alternator, etc.
