Chipper Jinma 6" Chipper Belt Question
   / Jinma 6" Chipper Belt Question #1
Dreamin_Tractors
Washington
NH T2320 Hydro
I have seen several people that have changed the mechanical feed belt with a Gates PowerRated 6838 belt. Wondering if anyone knows of the Gates part number for the main drive, or if it even needs to be replaced?
   / Jinma 6" Chipper Belt Question #2
These are Dayco Numbers.
Always use an industrial belt.
L544 times 5
L438 times 1
I serviced a new chipper today that the customer requested that I go ahead and replace the belts with US belts. Replace now or later.
Ronald
Ranch Hand Supply
Thanks Ronald. I assume the L438 is the belt for the feed roller.
   / Jinma 6" Chipper Belt Question #4
Yes, that is correct.
The numbers can be crossed to other MFD's of belts.
While the feed roller belt is off........ it would be a good time to check the set screws in the pulleys.
Ronald
Ranch Hand Supply
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
1266 (A50490)
1266 (A50490)
2006 John 4 x 4 cart (A50324)
2006 John 4 x 4...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
