Chipper Jinma 6" Chipper Belt Question
   / Jinma 6" Chipper Belt Question #1
Dreamin_Tractors
Washington
NH T2320 Hydro
I have seen several people that have changed the mechanical feed belt with a Gates PowerRated 6838 belt. Wondering if anyone knows of the Gates part number for the main drive, or if it even needs to be replaced?
   / Jinma 6" Chipper Belt Question #2
These are Dayco Numbers.
Always use an industrial belt.
L544 times 5
L438 times 1
I serviced a new chipper today that the customer requested that I go ahead and replace the belts with US belts. Replace now or later.
Ronald
Ranch Hand Supply
Thanks Ronald. I assume the L438 is the belt for the feed roller.
   / Jinma 6" Chipper Belt Question #4
Yes, that is correct.
The numbers can be crossed to other MFD's of belts.
While the feed roller belt is off........ it would be a good time to check the set screws in the pulleys.
Ronald
Ranch Hand Supply
ECHO CS-4920 GAS CHIANSAW (A57192)
ECHO CS-4920 GAS...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
Miniature Metal Goat Statue (A55853)
Miniature Metal...
2011 Ford F-250 Crew Cab Pickup Truck (A55852)
2011 Ford F-250...
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
