JM 254/284 Brakes
   / JM 254/284 Brakes #11
Just to clarify on my prior post. My apprehension was to do with the slopes I was on, and not specificly about the brakes. While it has been many years since I have been on a Ford 8n or 9n, my impression is that the Jinma brakes are better. FWIW.
   / JM 254/284 Brakes #12
If I read your post correctly ( if ).. then you were concerned about the brakes holding you still on a slope... My worn 8n brakes will still lock the wheel down enough that the tire will slide down the slope rather than the wheel turning... right brake anyway.. !
Soundguy
   / JM 254/284 Brakes #13
My concern was generated by the slopes I was on, and was concerned mainly with rollover. Watching for the smallest hole that a wheel might drop down into, that would really make things exciting, gets very tiresome, very quickly. The hour or two of work I did for the neighbor, felt like double that amount of time.
I can see why my post could have mislead that, but the main thing I was trying to get across, was that if I had to do that type of hill work very often, a wider wheelbase is probably in order. I don't know if I had set my wheels to the widest possition, would have made me pucker any less! Certainly wasn't going to do it, for a onetime favor.
If the brakes were a concern in my mind that day, it was only that they hadn't been tested to that level, before that. They did hold for me, with no slipping when I did make forward-reverse changes, and I did have to do that on the slope a few times. Not being familiar with other CUTs, I don't know if it was any better or worse than others.
In general, I plan to avoid slopes like that in the future, but its not because of the brakes. /forums/images/graemlins/blush.gif
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
