epic6500sr,
You could also look at the 3203 - depending on what your needs are. The 3203 is a direct-injected
(vs. the L3130's indirect-injection) 32hp unit with our older linkage style Hydrostatic transmission
(instead of the electronically controlled eHydro on the 3x20 Series) and rigid ROPS.
The 3203 is one of our "Advantage" series tractors, so there are no options like a mid PTO or rear hydraulic outlets available. The "300" is the only loader available, and it is a little light in the lifting department - 547# for the "300" vs. 997# for the "300X" and 1,047# for the "300CX".
(all weights are at full height, (88" on the 300 and 300X, 101" on the 300CX) at 500mm in front of the pivot point) This is due to smaller pumps running at lower pressure.
(3203 implement pump is one full GPM lower, and 350 psi less than the implement pump on the 3x20 Series) Again, depending on what you need to do, these differences may push you back to the 3120 or 3320...
I would definitely recommend that you drive them both - preferably one after the other - as there is a definite difference in the "feel" of the pedals. If you have driven a Kubota L3x30 series with the HST transmission, it is also linkage controlled, so it should feel more like the 3203.
The difference in cost is pretty substantial: The 32hp 3203 Tractor with 300 Loader lists for $18,449.00, while the 29.5hp 3120 Tractor with 300X Loader lists for $20,621.00 and the 32.5hp 3320 Tractor with 300CX Loader lists for $22,226.00! If the lower specs on the 3203 / 300 are not a problem for what you are doing, it must just be the "right" tractor for you. Anyway, I hope I was of some help.
