John Deere 3320 smokes blue on start-up
   / John Deere 3320 smokes blue on start-up #11
Ditto on the thanks for the training Tom.
   / John Deere 3320 smokes blue on start-up #12
Tom--my thanks as well. I've noticed the same thing since day on my 3320.
   / John Deere 3320 smokes blue on start-up #13
Hello Gents, this is my first winter with my 3320 (it only have 11 hours on it) and I get the same blue smoke for a few seconds at start up.
My secondary concern is that it takes probably a good 4-5 seconds for the engine to turnover on a cold start. Is that normal?
The Owner's Manual says to push in the key for 10-15 seconds before starting to help warm up. I have tried that and it doesn't seem to help. Do they really mean to push in the key or to turn it just so the battery kicks on?
   / John Deere 3320 smokes blue on start-up #14
here's what i do.:
1) turn the key to the first knoch - and let go of the key - allowing the dash lights to come on and wake up.
2) from that key position - push the key stright in - for 15secs. and release
3) turn to next knoch to start.
My old 3720 started very fast. I have a brand new 4720 that did/does not start as fast, but seems to start quicker each time. I don't know if it's changing or I'm getting use to it.
   / John Deere 3320 smokes blue on start-up #15
here's what i do.:
1) turn the key to the first notch - and let go of the key - allowing the dash lights to come on and wake up.
3) turn to next notch to start.
In addition to this, try letting the engine idle a minute or two at slowest speed before shutdown. Start the engine with throttle at idle setting.
   / John Deere 3320 smokes blue on start-up #16
............ Do they really mean to push in the key or to turn it just so the battery kicks on?
They really mean it. :) Switch to on, and push IN so you see the light on the dash. Count to 10, and then turn to start. Much much better when there is warm air sucked in to fire it off, and keep the blue smoke to a minimum.
   / John Deere 3320 smokes blue on start-up #17
Perfect, thanks.
The manual didn't say to turn the key to the first notch then push in. I will give it a go.
   / John Deere 3320 smokes blue on start-up #18
I get a pretty good cloud of blue smoke from my 4010, particularly now starting it in the cold. I glow it for 6 seconds, and it fires instantly. HAVE ALWAYS had the blue smoke on startup, a little bit in summer & big cloud in winter.
First diesel (3rd diesel car) to not do this is our 2010 VW Jetta TDI. No smoke, no diesel clatter, just lots of torque from a fine diesel engine.
Ralph
OK, so I was in a panic when I posted this original thread back in 2008 as a new owner of a new tractor. You guys schooled me good and quick. My dealer was pretty forgiving too. I appreciate that. You know, I guess my tractor still smokes on a cold start-up but I don''t really notice it anymore. I had 300 hrs logged last I checked.
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Loflin 48 Inch Pallet Forks - Global Carrier (A55218)
Loflin 48 Inch...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
1709 (A54756)
1709 (A54756)
