John deere 3320
   / John deere 3320 #11
2008 model here, the only problem was the tilt steering wheel which would slip out of position when pulled on, a known problem and repaired under warranty. Also the battery at 5 years which is probably just a normal maintenance item but it went quickly when it did which caused me concern thinking I had a major electrical problem. The tractor started normally in the morning and ran fine, then after lunch tried to start it and nothing, just flashing dash lights, jumping it did nothing , just flashing dash lights. Called the dealer and he said he'd seen similar recently and to replace the battery so I did and its started and ran fine since then. My guess is some sort of internal failure in the battery probably caused by vibration.
   / John deere 3320 #12
I've got a 2006 JD3320 with about 500 hours on it. Still has the original battery. No issues other than normal. Great machine.
   / John deere 3320 #13
2007 3520 here with about 280 hours or so. Only repair was a busted loader line (my fault, had something hit it), and the brakes like to get cranky sometimes but that is a quick fix when it happens. Been extremely pleased with this tractor though so no real complaints here.
   / John deere 3320 #14
i have a 3520 which had the exact same problems as eric replace the baqttery and fix the tilt steering.
   / John deere 3320 #15
Check out the review section of the main page. Plenty of opinions on 3320 deeres there.
   / John deere 3320 #16
500 hours of very tough work and not a problem. I did rip off the oil filter working in some thick brush but that was operator error.
   / John deere 3320 #17
I've had my 3320 since 2006. I've been kind of hard on it - I put gasoline in it and had to have one injector replaced - I over-reved it in lowest gear, made the Tachometer needle nonfunctional, and had to replace the dashboard. The only thing I had to do that wasn't owner abuse was to replace the battery when the contents somehow managed ooze out and corrode stuff (I pushed down the caps, but still). Other than that my beloved JD 3320 is a green dream.
   / John deere 3320 #18
1,450 hrs+ and going strong, new Dec '07. Org battery still going good. Also had MFWD sensor replace in early '08 but I was pushing a lot snow at 8,500'.
   / John deere 3320 #19
I've got a 2012 3320 that has a little over 100 hours on it. Mostly loader and backhoe (485) work. It's been great and I've had no problems at all.
Frank
   / John deere 3320 #20
Have 06 3520 with cab. Bought 6 years ago with 240 hours. Just under 1000 hours now. Plowing snow, backhoe, tiller, brush hog. No problems, it is excellent. Considering belly mower
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2020 DRAGON ESP...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2013 JOHN DEERE 650K LGP CRAWLER DOZER (A52709)
2013 JOHN DEERE...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
