John Deere 4110 Service
   / John Deere 4110 Service #1
Agent Blue
Platinum Member
Another go around with the hydraulic oil and filter. @ Near twenty dollars a gallon I hope there is magic in the Hy - Gard transmission oil. I guess if it moves things correctly it is a must. The trouble is justifying a $35.25 filter Kind of grinds on my assumption of '' being held up without a metallic object ''. For a spin on filter which resembles a five dollar Fram, it does not look that special. I should cut one open to see the secrets involved. I bet it is the same tin / paper filter with JD colors.
For the front axle I assume SAE 80 - 90 is adequate. This has never been changed since new.
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
