John Deere 4400 no power to panel
   / John Deere 4400 no power to panel #1
Griff R
John Deere 4400
Have A jd 4400. Was snow blowing this am and when i went to turn on the flashers the whole tractor stopped with no power.
The panel has no power. Battery is charged. Power is getting to the ignition key switch. All Fuses seem to be good...help!!
   / John Deere 4400 no power to panel #2
When you say you get power to the switch are you testing at the switch? Do you get power out of the switch?
tested the harness battery terminal to ground and got 12v. I have tried to test the switch but don't know exactly what to look for.
How would i test power out of the Switch?
   / John Deere 4400 no power to panel #5
If you can get to the back of the switch you should have power going to the switch with key off on terminal 1. With key in run position you should have power to the red wire on terminal 5. If not I would think you have a bad switch.
6 terminals labeled BAT,ACC,ELX,IGN,ST,AID,GND
   / John Deere 4400 no power to panel #7
Okay Bat should be hot all the time. Turn key on and see if any of the others have power.
5 is IGN. when i do a continuity test on switch from bat to ign it shows good. When i plug the switch in i Get 12v on bat(which is 1) in the off position but nothing on 5 when i turn to run? Is switch bad even though it shows continuity from 1 to 5 in the run position.... can i stick a jumper between 1 and 5 of the terminal and see if i get panel lights?
   / John Deere 4400 no power to panel #9
Yes you can try a jumper wire.
Nothing. BAT to ground on the frame gives me 12v but Jumping Bat to IGN or does nothing. Tried ACC too. and i do not get any panel lights at any time.
Do you know what might kill all power to the panel?
   / John Deere 4400 no power to panel #12
I posted the diagram for the power circuit and there is a fuse after pin 5 but you should have power at the switch in on position if you have power to the battery pin. If not the switch is not making the connection. With the jumper wire if no power to the panel I would locate that fuse.
   / John Deere 4400 no power to panel #13
I like a pin light to troubleshoot wiring issues. Do you have one?
It was the fusible off the starter. It powers the panel.
oops! Fusible link
   / John Deere 4400 no power to panel #16
The fuse panels on my John Deere 4400 suck they have been a pain in the rear end since I bought the tractor new.
2008 Volvo XC90 AWD SUV (A59231)
2008 Volvo XC90...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
VR59 Hydraulic Vibratory Roller Skid Steer Attachment (A59228)
VR59 Hydraulic...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
