John Deere 445 fuel injection left side cylinder not firing
   / John Deere 445 fuel injection left side cylinder not firing
I do get fuel flow when I turn on key. The flow seems strong but I never checked this when it was running good, so I don't have a comparison. I did remove the fuel return line that goes back to the tank. I removed it while the engine was struggling to run. I had lots of gas flowing out of this. By the way, engine does keep running even as plenty of gas comes out of hose.
So, I'm still getting the poor running engine. The governor keeps cycling the engine higher rpm back to lower. I did remove the vacuum hose that attaches to the MAP sensor and it certainly changes the pitch of how the engine sounds. Not nearly as much governor cycling, but by no means back to normal.
Looking for more ideas as I will try to work on some more today.
Thanks
   / John Deere 445 fuel injection left side cylinder not firing #12
Thanks
This maybe a long shot. My 425 had a cylinder failure. Cause was a leaking intake gasket letting coolant leakage into one cylinder. Let tractor rest overnight, then pull both spark plugs. Turn motor over by using fan manually, and have a look inside the cylinder for liquid inside.
Hope it isn't the problem.
Good luck.
2020 Nissan Rogue SUV (A44572)
2020 Nissan Rogue...
NEW Fork Extensions (A48289)
NEW Fork...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A48561)
2019 Energreen EVO...
2005 INTERNATIONAL 7600 REAR LOAD TANDEM AXLE GARBAGE TRUCK (A45676)
2005 INTERNATIONAL...
1671 (A44572)
1671 (A44572)
2005 VOLVO VNL670 SLEEPER (A45676)
2005 VOLVO VNL670...
