John Deere 4600 and 5520 Fuel Gauge Problems
   / John Deere 4600 and 5520 Fuel Gauge Problems #1
glcaines
Hiawassee, Georgia
JD 4600, JD 5520
I have a JD 2003 5520 cab tractor that the fuel gauge went bad on several years ago. When empty, the gauge reads full and when full the gauge reads way past full. I also have a 2000 JD 4600 that developed the same problem today. I went to a JD dealer about the problem on the 5520 tractor several years ago, and they told me to forget having it repaired as the cost would be somewhere between $750 and $1000 because the whole instrument cluster had to be replaced. They also told me the new replacement would likely fail just like the old one in a few years. They told me this was a common problem. They also told me that they weren't repairable. Does anyone know what exactly fails in the instrument cluster? I might try to repair it myself with some information. All of the other gauges work fine on both tractors. Alternatively, does anyone know of a repair facility that can fix these?
It isn't that much of a problem for the JD 4600 because you can remove the fuel cap and tell the fuel level. For the JD 5520, this isn't possible.
Thanks for the tip! No, I didn't look on Ebay.
New/Unused Quick Attach 72in Skid Steer Mulcher (A51573)
New/Unused Quick...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
50ft Fuel Line (A51573)
50ft Fuel Line...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
