John Deere 4600 and 5520 Fuel Gauge Problems
   / John Deere 4600 and 5520 Fuel Gauge Problems #1
glcaines
Hiawassee, Georgia
JD 4600, JD 5520
I have a JD 2003 5520 cab tractor that the fuel gauge went bad on several years ago. When empty, the gauge reads full and when full the gauge reads way past full. I also have a 2000 JD 4600 that developed the same problem today. I went to a JD dealer about the problem on the 5520 tractor several years ago, and they told me to forget having it repaired as the cost would be somewhere between $750 and $1000 because the whole instrument cluster had to be replaced. They also told me the new replacement would likely fail just like the old one in a few years. They told me this was a common problem. They also told me that they weren't repairable. Does anyone know what exactly fails in the instrument cluster? I might try to repair it myself with some information. All of the other gauges work fine on both tractors. Alternatively, does anyone know of a repair facility that can fix these?
It isn't that much of a problem for the JD 4600 because you can remove the fuel cap and tell the fuel level. For the JD 5520, this isn't possible.
Thanks for the tip! No, I didn't look on Ebay.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A45336)
2019 Generac...
2011 Ford Edge SEL SUV (A46684)
2011 Ford Edge SEL...
2004 Big Tex 10PI T/A Pipe Top Utility Trailer (A45336)
2004 Big Tex 10PI...
Pex Crimp Tool Set (A45336)
Pex Crimp Tool Set...
New Wolverine 72'' Skid Steer Grapple Bucket (A48289)
New Wolverine 72''...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A46683)
2017 Mack GU713...
