John Deere 5075e verses 5075m
   / John Deere 5075e verses 5075m #21
Final Tier IV seems to have fewer problems than interim Tier IV. Having DEF seems to be a better situation than a tractor with Diesel Particulate Filter - DPF and EGR - exhaust gas recirculation... (Don't you just love all those acronyms!). Biggest concerns seems to be - what happens when the tractor has 4000+ hours and you have to replace the SOC and the DOC - selective oxidizing catalyst and diesel oxidizing catalyst.
Today's cost is somewhere in the neighborhood of $7,000-8,000!
As ovrszd stated, the new tractors, trucks, all have it! If you're looking at a new machine - you will have a DEF tank!
Friend of mine owns 8 over the road semis. 3 are final Tier IV. They are the least problem.
The road grader I run is Interim Tier IV with a DPF. It's estimated cost is $4000 to be replaced at 4000 hours.
   / John Deere 5075e verses 5075m #22
Thank you Brett. But you say to consider 5085e or 5075 and that the e series is larger. Are the 5075m and the 5075e the same size ? I'm told the e series has more bells and whistles.
Thank you magician 710. My plans are to match a seppi mulcher to the tractor for more serious brush clearing. Brush oak mostly 1" thick to 4" thick. Occasionally 5"&6". Continue to mow lots , pastures, spread dirt and root grubbing. I stay busy 30/40 hours a week 10 months a year.
Your bush hogging 4-6" oak? What kind of cutter can withstand that? Oak is very hard to cut and I'm surprised that anything other than a Brown Tree cutter can handle that size material???
   / John Deere 5075e verses 5075m #23
Oh I see now a mulcher. That sounds interesting will have to look that up.
   / John Deere 5075e verses 5075m #24
I bought a used '15 5075E last fall, and I like it just fine. Hydraulics seem to be more than adequate using the FEL and it has plenty of pressure/flow even at low RPMs. I am not running a mulcher, just a JD 609 bush clipper, a spin ditcher, etc. Nothing too taxing.
The only thing I don't like so far is the air filters inside the cab are a PITA to get in and out. Other than that the AC/heat works great. Moving up form a 685 IHCase open station, this was a big step!!!
From what I have read, the DPF has to be serviced at 3500hrs and should last up to 8,000hrs before replacement. I am good with that. Mine doesn't use DEF so I guess it is not a tier F. But my 8310R isn't either, and it works just fine.
So does the M have the two speed PTO like the E? I really like that feature.
Not sure built in India is such a bad thing. I have gear drives on my combine what were made in Spain, the injector pump on my 4960 from Japan, and my 685 was made in the UK.
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
