John Deere 709 Rotary Cutter Bush Hog
/ John Deere 709 Rotary Cutter Bush Hog #1
tlanham
columbia sc
jd 9500
Have a JD 709 Rotary Cutter gearbox to go tear up. Needs everything replaced shaft, bearings, gears, seals, etc. Know of anybody who rebuilds these gearboxes? JD wants a arm and leg for a new box and same for the parts. Will another manufacture gearbox interchange and save any money? Thanks folks for any help you can lend.
T. Lanham
South Carolina
/ John Deere 709 Rotary Cutter Bush Hog #2
What caused failure? Bottom seal? 709's have very rugged gearboxes. I've owned a 709 for many years.
Bottom seal started pouring oil and the "starring wheel holder" didn't know and continued to operate until everything torn all to ****. This make the 5th 709 I've owned and never a problem with a gearbox.
/ John Deere 709 Rotary Cutter Bush Hog #4
There are some chinese boxes on burden or shoup and you can get them on for around 200. I put one on a small woods and it want easy.
I would just get another cutter.
Yep probably good advise. Thanks for the time!
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
UNUSED MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED MINI...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
