John Deere Model 770 compact
/ John Deere Model 770 compact #1
kartvines
Last month I bought a compact John Deere 770, and yesterday I bought a backhoe attachment for that model, I can see where it connect on the bottom, but can not determine how else to mount it and then set up and use. This is my first tractor to own. I just bought a operator manual for the tractor. Any and all help would be really great.
/ John Deere Model 770 compact #2
What make/model backhoe did you buy? Is it subframe mount or just mounts on the 3pt hitch? Did you install the "Power Beyond" kit or does it have a pto pump? A little more information might help us help you.
The backhoe is the same model, 70, the perfect match to the tractor, it attaches to the sub frame, to the lower notched. I bought it from the same family that I bought the tractor, but the children knew nothing of how to hook it up. It does not attach to the PTO, the hoses connect to the connector to the right of the driver [remote valves] that is all I know. I admit that I am a novice. This is the first tractor I have owned. What is the "power beyond" kit? The family has told me that the back hoe worked great the last time he used it. But it has been sitting around for about 5 years since his death. Welcome any and all help./forums/images/graemlins/confused.gif
/ John Deere Model 770 compact #4
I looked on the net to see if I could find a picture of the 70 BH and didn't. I can tell you how my 448 BH attaches. I have to first remove the 3pt hitch components including the top link. Then I back up to the hoe and the rockshaft engages the hooks on the top of the hoe and lifts the hoe to the top and there are two pins that hold the assembly (one on each side). The power beyond kit is just a tap into the hydraulics of the tractor and has a hose for the fluid to loop. After pinning the hoe and killing the tractor, I remove the loop hose and plug in the two lins from the hoe. Not sure if this helps, but I could possibly send you some photos later if that would help. Could you post photos of your assembly? Maybe a shot of the sub frame mount and the mating parts of the hoe.
/ John Deere Model 770 compact #5
The 7 backhoe is a bit different than the 448 in attachment. There should be a sticker on the hoe that outlines the procedure. If you don't have that, I'll try to describe here. If that fails, I can post some pics, scan some instructions or whatever you want. I have a 7 on my 790 which is the same tractor as a 770.
All of this assumes your tractor has the Power Beyond and tractor-side mounting brackets. If not, it will never mount.
First, remove the three point lower arms, lift links and top link. There is a locking bar that will keep your rockshaft arms in the up position but I'm sure you can live without it.
Back the tractor up over the hoe until you can hook up the hydraulics. Once hooked up, raise the hoe using combinations of stabilizers and boom so the lower mount is even with the tractor bracket (height) and the front of the subframe is tipped down somewhat. Back up to engage the rear lower mount in it's slots on the tractor.
Again using a combination of stabilizers and boom, lower the rear of the hoe. It will pivot in the rear mount causing the front to raise and engage the forward subframe mounts. They should self-latch (make sure they are unlatched beforehand). Once latched, raise the rear again and hook up the upper mount to the top link hole on the tractor.
That's it. On a good day I can do all of the above in under five minutes! Raise everything up and you're off to the races!
Let me know if you need anything more. I have manuals and such at home /forums/images/graemlins/smile.gif
Rob
I did not see a sticker but I will look again, where would it be located? That sounds easy, too easy, the hoses seem short, so I can not see how they could attach. could you tell me where I can locate a manual? I just got my operator manual for the tractor in the mail today. Photos always help. I can take a photo of the backhoe, if I knew how to load them to this site. It has everything needed to run it , the family has told me that it was taken off and never reinstalled again because their father died. I will post the photo of when it was on the tractor.
Mike
Let me ask you a question,you said to move the tractor over the attachment close enough to connect the hyd hose. Let start there. My #7 backhoe attachment has two hose, what looks like a one foot hose with a male end and a two foot hose with a female end. Just above my PTO is a hose attachment . with the left side having a quick disconnect coupler, and to the right of the driver on the fender is another connector with two female ends. Where do I connect the hoses, which area above the PTO or the other connector?
Ok I was able to find a photo of the power beyond, I do have that unit, so now help me understand what the side mounting brackets are, the power beyond hose go to the unit with a lever on the right fender the one that has two female hose outlet. Is this the unit that you are speaking of?
/ John Deere Model 770 compact #9
The hose attachment above your PTO is the Power Beyond. With the engine off you can disconnect the jumper hose from one side of the connection. The connections will then be obvious to the backhoe as there will only be one pair each of male/female connectors. No way to hook it up wrong!
If you want a manual, try a John Deere dealer or their web site. I've also seen them on Ebay. I'll take mine to work tomorrow so I can scan you some images if you want.
Yes, that picture looks very familiar, it's just like mine except the tires. You've even got the ROPS extensions so you won't bump your head when your using the backhoe. I didn't use mine long before adding that option /forums/images/graemlins/smile.gif
/ John Deere Model 770 compact #10
<font color="blue">the power beyond hose go to the unit with a lever on the right fender the one that has two female hose outlet </font>
Well, now you've got me stumped but it may be one of those things that's harder to describe than picture. I'm bad about those things myself.
My tractor has only the power beyond. There is just one jumper hose above the PTO that has a hard connection on the right side and a quick connect on the left. The hose loops down below the top link on the three point hitch.
If you've got more hoses than that, you may have an extra valve plumbed in through the power beyond. I've heard that's done from time-to-time. If that's the case, there may still be a pair of power beyond outlets on the additional valve for the backhoe, or the extra valve may unplug with quick connects. Have another look and let me know. I'll run down now and snap a pic of my tractor /forums/images/graemlins/smile.gif
/ John Deere Model 770 compact #11
Here's some pics. First one is the rear of my tractor showing the power beyond connections. The LH fitting is a quick connect. The hose then hooks to the shorter hose on the backhoe and the longer hose on the backhoe connects to the LH fitting. Top link comes off for the backhoe /forums/images/graemlins/smile.gif
/ John Deere Model 770 compact #12
Another shot from above. The side links and lower arms also come off for the backhoe /forums/images/graemlins/smile.gif
/ John Deere Model 770 compact #13
Here's a shot of the rear backhoe mount on the tractor. The backhoe has a crossbar that engages in this bracket. The crossbar has a "hickey" in it to clear the drawbar pocket area /forums/images/graemlins/smile.gif
/ John Deere Model 770 compact #14
And finally for tonight is a shot of the front mount on the tractor. There are two, one on each side. This is the RH side, taken from in front of the rear tire. The latch is in the open position as it should be when installing the backhoe.
My backhoe is outside ( /forums/images/graemlins/frown.gif ) otherwise I'd snap some shots of it as well. I can do that tomorrow but it sounds like any differences you may have are on the tractor side of things. Hope this helps and as I mentioned I can scan some manual images tomorrow at work /forums/images/graemlins/smile.gif
Thank you very much for all of your efforts. I have downloaded the photos and information. I welcome anything else you may be able to offer, look forward to the balance of the information. I have located a manual for the 7 backhoe on Ebay. so the bidding now begins. That is the same place where I just bought the operator manual for the tractor. You have been a lot of help. By the way you said my tractor has the ROPS extensions , do you mean the added part to the stock roll bar?
Mike
/ John Deere Model 770 compact #16
Yes, the ROPS extensions are the added section towards the top of the roll bar. Without it you're sure to bang your head when getting on/off the backhoe. I have my manual with me today but am pretty busy. Hopefully, I'll have a chance to do some scanning later today. how does your Power Beyond hookup look versus mine?
My power beyond looks just like your, but instead of having a looped hose, both of my hoses connects to the what I guess I will call the auxiliary unit on the top of my left rear fender. From that I have an extended two female connections facing to the rear of the tractor. If I have the time this week end I will take a photo and post it.
/ John Deere Model 770 compact #18
OK kartvines, I'm going to try attaching scans of the installation process. This is from the operators manual.
From your description of your hoses, you must have an auxilary valve plumbed into the power beyond. Did your backhoe come with the tractor you have? If so, it's probably plumbed to work from the power beyond ports on that valve. You'll just have to look at the various connections and see what makes sense. It is a bit troubling that you would have two female connectors as you then have the possibility of plumbing it backwards. Not sure what that would do, but I wouldn't want to try it /forums/images/graemlins/smile.gif
Well, my .pdf file is too big to attach. I'll find another way. If you send me your email via a private message I can email you the .pdf scan /forums/images/graemlins/smile.gif
Rob
I just won another ebay book, the operator manual for the john Deere #7 backhoe. Is this the same book you have and are referring to? I must now pay for it and wait for it to be shipped. As far as if my backhoe attachment came with the tractor. I do not really know. I first bought the tractor, and then the backhoe from the same family, so it may have. I am taking an extra day off during this 3 day week end, so I will have more time to finish some of the project I need to get down, I will take a photo of the unit and then post it. Right now the hoes form the beyond power is linked to this unit.
/ John Deere Model 770 compact #20
That should be the same manual as what I have. I also have the parts manual which shows exploded views and all the part numbers. I think I have the hydraulics manual as well which goes into some troubleshooting and such. I suspect you'll be able to figure everything out. The only glitch you may have will be with that auxilary valve and I won't be of much help there. Some pictures will surely draw some help out of people more knowledgable than me /forums/images/graemlins/smile.gif
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
