John Deere X758 vs Kubota GR2120
   / John Deere X758 vs Kubota GR2120 #11
FYI: I currently have a Kubota L3010 GST tractor, with front end loader and various attachments;
The mower will only mow grass, and the deck will never come off of it; No need for any attachments on it.
The BX is a very good machine, but I am wanting full-time AWD, that won't tear the grass up; Not wanting to engage, disengage 4wd when needed in the more challenging areas. The GR or X758 would be more maneuverable also than a BX.
This issue with the ZD326 is not the deck; It cuts great, and love the diesel. It is a tank. The unit is very heavy, and as careful as I try, the unit is leaving 1foot bald circles in my yard. Constantly looking at the rear tires in turns, trying to keep both moving, doing 3 point turns, etc.
Kubota has updated the model of the GR this year as a GR2120-2-54.
Anyone know what the -2 entails?
Have all the bug and issues been worked out of this GR? Have read about it slowing down going up hills once the unit/transmission heats up.
Haven't heard any real negatives around the X758 though. But more money. Again AWD needed and cutting grass only with it.
Thanks for sharing your experiences, as it will steer my buying decision!
If turning and tearing up the lawn is your concern then test drive the X758 & GR mowers. On my X540 the deck gauge wheels leave marks when turning (I.e. rings around trees) & I have seen other complaints about this as well. Yes I have them raised up but when turning the deck tilts and the gauge wheels hit. the X7** series uses a different style deck so this may not be a problem with that model.
   / John Deere X758 vs Kubota GR2120 #12
The x700 series has models with all wheel steering if you're concerned about the tires damaging the lawn. Maybe a more maneuverable machine will help your cause as well. Good Luck
   / John Deere X758 vs Kubota GR2120 #13
The x749 with all wheel steer and hydraulic 4x4 varies the speed of the front wheels in turns to limit scuffing of the tires. I have had mine for 6 years now and never have a scuffing problem. The x758 has the same front hydraulic axle and no scuffing with it either.
   / John Deere X758 vs Kubota GR2120 #14
I cannot help with what the difference is with the GR2120-2. Have you asked your nearest dealer?
The GR2120 is an update from the GR2110 and GR 2100. Updates to the GR2120 include rods instead of cables to activate glide steer, and transmission updates such as bearings instead of bushing. I am sure there are others...
I have had my GR2120 since summer of 2013, no issues with transmission, and I use it mow the banks on our pond, main reason I got a 4WD lawn tractor (plus snow blower). The steering is effortless, traction is incredible, and with the glide steer, I have never torn up the grass due to turning.
My suggestion, test drive.
Good luck! Philip.
Bunker Rake (A59228)
2003 Big Tex 10PI...
DIRT DOG GRB72 72" GRADER BOX (A58375)
DIRT DOG GRB72 72"...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56436)
2006 Tusk 500...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A56858)
2006 Ford F-650...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
