riptides
Super Member
I was waiting for you to chime in Eddie. Here is the attack plan:
-Thatch in new shingles today
-have water & power turned on then hope I don't hear hissing or smell anything burning
-tractor and bush hog the overgrown back yard that blocks a fantastic view down the valley
-haul off all the 'stuff" inside including the flooring and water damaged ceiling sheetrock insulation & flooring
-bleach all surfaces
-repair ceilings & either re-popcorn or scrap it all off, or use drywall mud and brush print ceilings
-tape off an spray kilz on all ceilings & walls(yes this is a must ...trust me)
-paint ceilings & walls with semi gloss white
-carpet the bedrooms, laminate the kitchen, living room & hallway
-repair/replace ac unit
-replace front and back door, both have been kicked in more then once
-repair existing covered deck, then build additional open deck(10x15ish) to take advantage of the backyard view
-install new fridge & stove
I can't remember what was down in the bathrooms, vinyl or tile so both may need to be replaced. I am sure i missed a few things, but that is the bulk of it. I already crawled into the crawl space and saw nothing terrible except spyders, vapor barrier was intact and it was dry.
Ditch the pop corn, mud use gets expensive on time and effort, IF your not good at it.
Ditch the semi-gloss. Flats hide imperfections and allow easier paint overs later.
IMHO
