Just bought used Kubota L2800/keeps shutting off
   / Just bought used Kubota L2800/keeps shutting off #11
check the seat switch. mine will move a couple of feet if your not the seat then shut off. i would try sitting on the seat and going to full throttle without touching the pedal and see if it shuts off. if it doesnt then that may be a fuel issue otherwise it sounds like something electrical is acting up from the way you describe it I would suspect the seat switch.
   / Just bought used Kubota L2800/keeps shutting off #12
The fuel system could be set in "bleed" mode and allowing air in. Read the manual on how to change it.
The fuel filter could also be clogged up -- change it.
The fuel could have water in it - you'd see it in the filter housing.
The air filter could be clogged up -- or the air hose could have a mouse nest in it. Blocking the air.
The muffler could have a mouse nest in it blocking the exhaust out. That's usually evident by the smell :laughing:
The safety switches could be messed up - including the stop switch listed previously.
On the whole, I wouldn't panic just yet. It's probably a simple issue that will have a low cost fix.
HYDRAULIC MOTOR SKID (A55745)
HYDRAULIC MOTOR...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
