Just ordered a FEL for my BX2230
   / Just ordered a FEL for my BX2230 #1
nysdotinspector
warwick n.y. orange county
kubota bx2230
I"m intrested to know if I"ll be able to dig virgin ground with my FEL. MY main uses will be for gravel and woodchips, but who knows, I may want to dig some dirt. I would also be willing to buy a weight box if need be. Thanks
   / Just ordered a FEL for my BX2230 #2
May as well start shopping for a tooth bar.
Loaders are just that...for loading loose materials.
Digging in dirt requires more pressure per square inch then the front bucket can deliver. However, the tooth bar will concentrate the digging force enough to break the dirt up...to a degree.
Don't think you're going to dig a house foundation...you're not.
But, using the tooth bar to break up or back drag clumpy dirt, then using the loader to move that dirt...works pretty well.
But, you've got a CUT, not a 15 ton Industrial Front End Loader. Know the limitations of your tractor and work within them.
Get that toothbar..you'll be glad you did!
   / Just ordered a FEL for my BX2230 #3
What Roy said. /forums/images/graemlins/smile.gif I have a BX2230 and am in the process of getting the parts to build my tooth bar. I have a box so I can do some break up with that but I need to dig and since winters over here in so cal I need all the help I can get. /forums/images/graemlins/smile.gif
Steven
   / Just ordered a FEL for my BX2230 #4
You'll definitely want weight on the back of that 2230 if you are picking up any significant amount of dirt. I just bought a 2230 with bar tires, FEL and toothbar for the small chores where the big tractor is overkill. I get the sense it will do some digging, but it is a bit light for really heavy work. Needs ballast in the tires or an implement out back, preferably both, to keep the back end on the ground. If the operator weighs more than, say, 200 lbs, that helps too. /forums/images/graemlins/crazy.gif
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
2014 Chevrolet Tahoe 4x4 SUV (A52377)
2014 Chevrolet...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
