Kama TS254C Fuses ratings
   / Kama TS254C Fuses ratings #11
After testing every circuit with my amp meter, I was able to determine the exact amperage fuse required for all the circuits.
NOTE - YES you can us a clamp on DC amp meter to measure current draw.
I then installed the appropriate fuse to protect the circuit being fused.
Here is the finished product:
And FINALLY we are done! Rob is a VERY HAPPY CAMPER!
He was so happy Rob Almost hugged me - so I changed the subject to Hunting.
This was a great time and I wrote all about my other Camp adventures with Rob & Loretta at there 3RRL camp in the appropriate section.
Larry
That's great stuff guys.
I decided to keep the old block in place and use in-line fuses because someone wrote that it would be hard to find a fuse block that would fit in the same spot, and it would not be good to drill more holes, and other negative stuff. But after seeing that installation I think I'll go with the new block.
ALSO--------------You must tell how you post those pictures on this site. I've been using the Photobucket site but would rather post pics directly here like you do.
Thanks again for the help---Geo.
   / Kama TS254C Fuses ratings #14
Off topic...
Posting thumbnails is easy and I'll walk you through it.... lol ... But I needed help too figuring it out, and Larry helped me.
Ok so first thing is to re-size your photos to make them around 50 to 100 kb size. This will help the dial up members. I use a Windows Picture Re-sizer that is free to download.
When I open or preview a picture, right mouse click on the photo and one of the options will be to "resize" the photo. I usually use "medium" setting and large only for more detailed ones. Here is the link to the Windows Picture resizer.
Window Picture Resizer
Or do a search if you don't have XP for the computer system you have.
When you re-size a picture, it makes a copy of the original photo so it is not lost. I keep the resized pictures in a separate folder under TBN photos, under individual folders for each project.
OK, once you have a folder of resized pictures, you can log on to your photobucket account and also log onto TBN and to the thread you want. So now you have 2 web browsers open at the same time.
Minimize the TBN and go to the photobucket web browser. I have made sub albums in the photobucket account for each project too. Make one for "Boxblade" and click on it so you are in that sub account and upload those pictures to that.
Once the photos are upload, they will all appear as thumbnails on your screen. Below each photo is a square box with the name of the photo and also 4 types of formats, but disregard those.
What you want to do is check that box by the photo name by clicking on the box. You can check more than one photo at a time if you want. It will highlight the photo(s) and puts a red border around it.
After checking the box(s), scroll all the way down to the bottom of the page. There is an option to select/unselect all and also 3 rectangles below that.
You want to click on the one that says "Generate HTML and IMG code".
Click on it and another screen pops up with 5 more rectangles.
You want the 3rd rectangle down that says "IMG clickable thumbnails for message boards - recommended".
Highlight all that is in the box and Right mouseclick on it to copy it.
Then open up the TBN browser and "paste" the information into the reply with another right mouse click.
When you "Pre-view" your reply, you should see a clickable thumbnail in it along with your written post. That is why I don't use the "quick reply" so I can check my spelling and also my photos.
Click on the preview thumbnail and it should open up. If good, post it.
Sounds harder then it really is, but like anything else, once you get used to it it's not bad at all. lol ... Like tying your shoe laces the first few times.
Try that and keep these instructions in your computer for reference. I should keep a copy of these instructions too, since many TBN'ers have asked me how to do this.
OK George, Best regards
   / Kama TS254C Fuses ratings #15
The New ATC fuse block fit PERFECTLY after drilling two new holes. I also installed two standoffs to move the new fuse block away from the metal and more forward for ease of fuse inspection and replacement.
Here it is installed ready for wires:
Larry
i would really like to know where you got this atc fuse box or what is the part no. for it. I know this is an old message. but maybe you are still there
Bennie
2004 GMC Sierra 3500 Utility Flatbed Truck (A60460)
2004 GMC Sierra...
CAT CB34 (A60462)
CAT CB34 (A60462)
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
CATERPILLAR D3LGP CRAWLER DOZER (A60429)
CATERPILLAR D3LGP...
