Backhoe Kelly Backhoe
   / Kelly Backhoe #1
scruffy
Veteran Member
East Tennessee / South Central Oregon
None (at present)
Hey you Texicans, someone in Victoria Texas has a Kelly Backhoe up for sale out on ebay, the item number is:Kelley Backhoe Attachment Item #463830766 , Description: Kelley 3-pt. backhoe attachment. Also owner's manual. Will fit most tractors. $1200.Model 830FJ. Digging depth8'6".Reach 11'1".Weight 1125#.Runs off tractor hydralics. some surface rust,all hoses/valve body and cylinders appear to be in good condition.
Auction ends 10/19 @ 4 something p.m., it might sink a compact, I don't know. Have no idea what the size is.
   / Kelly Backhoe #2
May not sink a compact, but might break one in half. I've got a Kelly 3ph B600 which weighs about 550# on my Ford 1710 (24hp @ around 2400#). 3ph backhoes are stressful on tractors, and the B600 is about as big as I'd want to go. Even with the relatively small B600, I try to avoid using it really hard.
The B600 has a depth of 6' and an additional 2.5' on the arms would put a lot more stress on the tractor frame. The auctioned unit is about 2 steps larger than my B600. I think many compact 3ph's would lift the larger unit, but I don't think I'd want to use one much, except maybe on a beach.
The specs advertised for most hoes may be a little misleading. Max depths are how low the bucket can physically go. However, actually digging at the max depth is impractical. The bucket is extended almost straight down in the trench close to the tractor wheels, and you can't drag the bucket back further. It's also a good idea not to dig close to the tractor or else you might end up in the hole. A better spec than max depth to follow is depth with a 2' trench bottom, which means that the bucket can be dragged back 2' at that depth. It also means that the tractor has to be repositioned for every 2' of trench.
I suspect that manufacturers are a little generous to themselves with their specs. The depth specs might be given with the bucket extended straight down, which is not the best digging angle. Anyway, trenching at more than 5' with my 6' hoe starts getting impractical. I end up using the wrong digging angles and spend most of my time repositioning the tractor.
2020 CATERPILLAR 246D3 SKID STEER (A60429)
2020 CATERPILLAR...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
