Kerosene fired torpedo heaters????????????
   / Kerosene fired torpedo heaters???????????? #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Does anyone know anything about these heaters or own one? I was thinking of buying one to heat the project barn so I can work on it during the winter. I just don't know if it will smoke me out or not. The building is 36x60 and 2 stories tall.
TIA, Jim R.
   / Kerosene fired torpedo heaters???????????? #2
I have a 180,000 BTU model that works great as long as I use K1. It will work fine with diesel, but will kill you unless you have a gas mask.
   / Kerosene fired torpedo heaters???????????? #3
They work great.
About the only time they smoke is when they are running out of fuel. They do have a burnt kerosene odor but they are lifesavers on construction projects.
Just be sure you have adequate ventilation, they will burn up a lot of oxygen.
Bill Tolle
Thanks guys, I will look into them a litle more now. I can vent the building with no problem as the floor boards are not nailed down.
   / Kerosene fired torpedo heaters???????????? #5
I have had a 50k btu kero unit for a lot of years but it does have a little smell to it. Its not to bad but I like the propane unit a lot better, virtually no smell. The propane unit is also adjustable from 40-80k btu.
   / Kerosene fired torpedo heaters???????????? #6
We had one running the majority of the time we were finishing out our 24X36 pole barn. The smell wasn't bad but the noise level would give a deaf man a headache. (that's me)
   / Kerosene fired torpedo heaters???????????? #7
Would this be what I might call a 'salamander?'
   / Kerosene fired torpedo heaters???????????? #8
I believe so. That is what I get out of the description. Gerard
   / Kerosene fired torpedo heaters???????????? #9
I like the propane ones myself, less smell. Leave the tank outside. If your in a semi closed area, Invest in the thermostat. Usually a separate item, very handy so you don't spend all afternoon putzing with the heater instead of working. /forums/images/graemlins/wink.gif
Gary, yes salamander
   / Kerosene fired torpedo heaters???????????? #10
We use one to bring the temp up quickly in the shop in the morning, then heat with wood. Lots of heat, very fast, very concentrated if you need it to be (we sometimes blow it on a block to warm a hard to start unit), but oh so NOISY! And ditt on #1 vs. diesel. It will burn diesel, but smells worse.
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
