Kerosene Heater - I’m stumped (?)
   / Kerosene Heater - I’m stumped (?) #11
Similar problems with my 55k BTU. Ended up getting new air pump rotor with 4 new vanes and an air filter kit and cleaned fuel filter. These are wear items and need replacing periodically which I never have done. Used an air pressure gauge to set air pressure.
The heater uses air pressure to suck fuel to an injector with a Venturi effect.
After repair, my unit worked for several hours until the igniter deteriorated and blew the fuse on the circuit board. I have gotten a new igniter and am waiting for the new (special size) fuse to arrive from Amazon.
Good luck.
Fuse finally arrived and unit is working well.
I used a fitting to screw an air gage to port in plastic cover on air pump. Replacement covers are also available.
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
KBH 25T Tender (A56438)
KBH 25T Tender...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
