King cutter scalps on one side
   / King cutter scalps on one side
Unfortunately, my "friend" and i arent talking anymore. He has fallen prey to the prescription drug problem that plagues us here in WV. So i am not sure he hit anything with it, but im pretty sure that he did. I will do as you said and measure the blade heights though.
Thanks for all the advise
   / King cutter scalps on one side #12
Sorry to hear of the loss of your friend, for whatever reason.
Once you check the height of the blade tips, is it possible to swap out the left and right spindles, or are they different part numbers?
I am suggesting this, if the blade tips are OK, maybe it is a spindle issue, and switching them out would tell if the spindle causes the left side to then scalp.
   / King cutter scalps on one side #13
If it is a pressed steel deck, he could have hit something hard enough to actually put a WOW in the deck which would need to be straightened or a new spindle would cut the same way. I bent a JD pressed steel deck like that once mowing my pond dike when I bottomed it out on top of the dike. It was an old deck with lots of rust so it bent pretty easily but if he hit a really solid object, he could have bent the housing and the spindle a bit. You could see this with the blade removed and a level across it in front/back and Side/Side directions.
   / King cutter scalps on one side #14
Can you lift it with a loader and hand turn the blades? Measure the blade tip heights and check to see if everything is level.
How big a tractor did your former friend use? If it wasn't 'power' matched to your mower it didn't bog down when he hit whatever it was and he wasn't fast enough to disengage it.
Things like that happen fast. I hit a piece of thin cable hidden in the grass and disengaged the PTO as fast as I could. The blades spun long enough to suck most of it up as I helplessly watched. The good news is that without PTO power, it didn't wind up very tight and apparently did zero damage to the mower.
   / King cutter scalps on one side #15
I've seen this done a few times. Belt breaks (from being smoked because something stuck a blade). New belt not installed correctly (belt threading diagram is missing or worn off). One blade is turning the wrong way. Tensioner adjustment is way out of range, too.
Just look at it when turning by hand. I presume you put the blades on properly....
I started taking things apart to where i could get to them. One side of the blade is 5 3/4 and one side is 3 3/4. The deck is definitely bent. I have no idea of how to straighten the deck, so I am going to take it to where i bought it and see if they can do anything with it. Pretty frustrating. Oh well....
   / King cutter scalps on one side #17
I'd take it to a local welder/machine shop and see what they say as to straightening it. They should be able to tell you if repairing/straightening is feasible.
   / King cutter scalps on one side #18
Ouch! Hopefully it can be heated and straightened. If else fails, you can probably cut the old mount out and remount it to new plate that can be welded back in.
   / King cutter scalps on one side #19
I agree with Coyote.......a good welder/machine shop can do wonders.
   / King cutter scalps on one side #20
I used to have a 6' King Kutter finish mower that I bought damaged. Owner had hit something so hard it twisted one blade and bent the deck, causing the right spindle to be tilted. Sounds like your deal. I beat on it with a sledge to get it back semi flat and then used some washers to shim the spindle back vertical. Did a good job mowing with it for years after that. Also watch for cracks in the deck around the wheel mounting brackets, had to do some repairs in that area too. Good luck.
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
CFG Industrial MH12RX (A50121)
CFG Industrial...
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
