JC-jetro
Elite Member
Great feedback, thanks.
I was thinking the seller used tapioca pudding!
Manual calls for gear oil GL5-85W 140 or triple zero grease.
I will leave the stuff in the top box, use 000 in the lower one.
Thanks again for the advise.
Mine Came dry, and I did use TSC traveller GL5-85w 140 Oil as well. I used it for both gear boxes the same. If you do use RTV Blue or what was recommended then you need to put a thin laye on one side after the edge wiped clean of oil and let it skin a bit before you put the cover on. RTV blue can be put as valve cover gasket replacement and once is skinned and cured it will stay put for a long time.
JC,
