King Kutter tiller-oil change question
   / King Kutter tiller-oil change question #11
Great feedback, thanks.
I was thinking the seller used tapioca pudding!
Manual calls for gear oil GL5-85W 140 or triple zero grease.
I will leave the stuff in the top box, use 000 in the lower one.
Thanks again for the advise.
Mine Came dry, and I did use TSC traveller GL5-85w 140 Oil as well. I used it for both gear boxes the same. If you do use RTV Blue or what was recommended then you need to put a thin laye on one side after the edge wiped clean of oil and let it skin a bit before you put the cover on. RTV blue can be put as valve cover gasket replacement and once is skinned and cured it will stay put for a long time.
JC,
   / King Kutter tiller-oil change question #12
I've got a 5' Tarter, but the design is pretty much the same as the KK II. I found that a suction gun works pretty well on the top gearbox (and makes for less mess). After slurping out the contents with the gun, nothing will drain from the drain hole at the bottom side. I just had to make sure to get tube routed down to the bottom edge of the box.
FWIW, when I drained the side box I did so by rolling the unit upside down via straps around the torque tube & doing the lifting with the FEL ...
I was flushing water contamination from the top box. I drained the side box because I had initially put in 85w90 and wanted to replace it with 85w140.
Nick
   / King Kutter tiller-oil change question #13
Nick
Cool:) This is my version of "suction Container/gun " using a my shop vac. It is "JC-the tool man" kind with a lot of ooomph:D
JC,
   / King Kutter tiller-oil change question #14
That "sludge" is grease, not oil with water in it. KK uses a flowable grease, 'oo' or 'ooo' I don't remember which.
I was going to post a question about this same topic yesterday. I checked my KK tiller out yesterday and the gearbox on top has that sludge in it. If it is grease, would there be any reason to change it? I checked the owners manual and it doesn't say anything about changing any of the oil in any of the gear boxes.
   / King Kutter tiller-oil change question #15
Brand new tiller, barely 3 hours on in.
I checked oil level at side gear box, level is fine although the oil is milky.
Should I remove the entire cover (roughly 10 bolts) to get a complete drain?
I dont know how yours was stored etc and they shouldn't get water in anyway normally but they come with a white looking grease in them called OO or something like that so it may just be the OEM lube and doesn't need anything?
Fact my manual says the OEM lube is compatible with regular 90wt and its ok to top them off with either fyi.
   / King Kutter tiller-oil change question #16
i have a king kutter(i bought used) finish mower,do i put gear lube or grease in gear box?
   / King Kutter tiller-oil change question #17
I would go to the King Kutter website and download a manual. But in general most gearboxes will call for 80W-90 or similar in them
   / King Kutter tiller-oil change question #18
^ This.
*When Adding Oil Use Multi-Purpose Gear Oil (I.E. S.A.E. 80w/90 or S.A.E. 85w/140 Multi-purpose gear oil) in Gearbox.
*For all Grease Fittings use TYPE/grade II tube grease.
   / King Kutter tiller-oil change question #19
Nick
I sure would have liked to witness that. I have the same tiller but it looks too heavy for me to see how to roll it over and then back up again once its lifted off the ground. Lifting wouldn't be a problem but how to roll it around while suspended in the air, letting it drain, and then rolling it back over without damaging the tiller or myself is the question. Sounds like a neat solution and hope you will explain in more detail.
Regards,
Clay
   / King Kutter tiller-oil change question #20
I changed the oil in my 6 footer the same way. Wrapped a strap around the tines and lifted it with the front end loader. Took the fill (drain) plug out with it hanging upside down.
TINKER AND RASOR HOLIDAY DETECTOR (A45333)
TINKER AND RASOR...
Godwin CD100S Dri-Prime S/A Towable Dewatering Pump (A44571)
Godwin CD100S...
2022 John Deere 6135E (A44501)
2022 John Deere...
Dynapac Walk Behind Trench Compactor (A44391)
Dynapac Walk...
Quick Attach Platform (A44502)
Quick Attach...
INOP/NON-RUNNING 2010 Ford F-450 Pickup Truck, VIN # 1FDAF4HR3AEB25362 (A44391)
INOP/NON-RUNNING...
