KingKutter tiller not quick hitch compatible?
   / KingKutter tiller not quick hitch compatible? #21
My KK tiller hooks to my quick hitch but I can't use the bushings. It wobbles a bit but I'm ok with that. The attachment arms on the tiller needed to be longer by "that much". (Holding my finger and thumb about 1/2 inch apart)
   / KingKutter tiller not quick hitch compatible? #22
If you look at the TSC site there tillers all now look like they will fit a quick hitch, but they are all country line not KK. My KK 5' tiller is like yours but it is older, you must have gotten a left over unit.
I got a KK branded one, not a TSC County Line branded one (they were cheaper, but out of stock of the 5'). I could very well have a slightly older model or something I guess.
When I was looking at TSC a week or 2 ago, the 6' one had County Line branding on it, but the manual was King Kutter.
I'll see if I can't shift the top link bushing down a bit. I might be able to bend the bottom link pin out just a hair with a crowbar, sledgehammer or something to get that 1/4" of clearance I need. If not, it seems to be working well enough without the bushings for now. I did end up with another quick hitch in a cheap pile of stuff from somebody downsizing, I should see if it has clearance issues too I suppose.
   / KingKutter tiller not quick hitch compatible? #24
I have the quick connectors that go on each arm. I bought a 7 foot KK tiller and it took me and 2 other people to get it to hook up. It is a bad design by KK. Nothing should be that hard.
   / KingKutter tiller not quick hitch compatible? #25
Why is it a bod design? It just weighs a lot so with out help or a quick connect system it's gonna be hard! Right?
Wolverine Quick Attach Hydro. Adjust Forks (A59814)
Wolverine Quick...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 844k-II AG HANDLER WHEEL LOADER (A60429)
JOHN DEERE 844k-II...
2004 Delta Spread-Axle Gooseneck Trailer. 20ft+5ft. (A56438)
2004 Delta...
