Kioti 2410 wont start
   / Kioti 2410 wont start #1
BigJoe67
Kioti CS2410
I have a Kioti CS2410 which will crank but not fire. I have replaced fuel filter and fuel pump. Taken hose off at fuel injector and when i run the pump, diesel flows. I have no smoke when it cranks. Not sure where to go from here
   / Kioti 2410 wont start #2
Check the fuse for the starter solenoid….
I believe it was the solution in the following scenario. TBD
While checking relays and stop solenoid, I found wire was broken at spade connector. Replaced connector and all is good. Thanks for the responses.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2020 JOHN DEERE 26G EXCAVATOR (A60429)
2020 JOHN DEERE...
LOT LOCATIONS (A59905)
403 (A52706)
403 (A52706)
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
