Kioti Backhoe Problem
/ Kioti Backhoe Problem #11
Here is another possible way for a dedicated source for the BH, and you don't have to bungee anything, and no jumper hose. Very simple to operate.
Install a ball valve to the IN port on the remote . Install a tee to the ball valve.
PB hose from the FEL will connect to one port of the tee.
The dedicated BH hose will connect to the third/middle port of the tee, and a short hose to a bulkhead fitting with a QD on it. This is your new BH supply port, or even log splitter supply port.
To operate BH, Plug in the BH, close off the remote ball valve, and the tank hose form the BH will go to tank.
For remote and 3pt operation, remove the BH hose, and open the ball valve. Even though there is a tee in the circuit, the male QD blocks the fluid from the tee, so then, fluid will flow through the remote and 3pt.
/ Kioti Backhoe Problem #12
1.Try it activating it to B port to make sure someone did not switch the hoses..
2.Since the cylinders attempt to extend but do not retract means the return side of the BH valve is blocked. Double check the B port coupler, look inside the female on tractor and make sure the poppet is not out of position. Take the male coupler off the BH return and put end of the hose in the hydraulic fill tube at rear of tractor and try it, if BH works then it is restricted at the tractor coupler or remote valve. If it still stalls, remove the one way flow valve at the BH valve return, reconnect the return hose and try again. If works now it is the flow valve not opening.
/ Kioti Backhoe Problem #13
KKempen,
Are you perhaps plugging into work port A on one spool and plugging into work port A of another spool.
You should be using A and B work port on the same spool.
/ Kioti Backhoe Problem #14
KKempen,
Did you ever figure out the problem?
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
KJ K2030 20'x30' Metal Garage (A60463)
KJ K2030 20'x30'...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
1408 (A57192)
1408 (A57192)
AGT Industrial M-DGR (A60463)
AGT Industrial...
2017 John Deere 5090GN (A53317)
2017 John Deere...
