Kioti CK 30 HST runaway throttle and wouldnt shut off.
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #11
None whatsoever..
Lower the pump and engage the pin on the control rack to the engine rack..
Some have a V notch that the pin sits in.. others have a hole in the engine rack that slides over the pump rack and held in place w a cotter/hitch pin..
Then push the pump down evenly and start the 4 bolts..
The pump will be under spring pressure so run the screws down evenly..
WHO took the pump off.??
Thanks. I took the pump off as the local repair main has been extremely busy. It was stuck. The manual shut off cover was stuck and could not be removed, so I had some issues getting it out. the manual cover can now come out. I know tht there is a plastic sleeve in there was concerned if it is in the correct spot etc.
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
